• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    *Wojtynek, Steve
    Aclyutil.arx still work?
    95 Views, 1 Replies
    09-28-2001 01:24 AM
    The first time I tried to plot in Acad2000 I was
    ill for a week.  (What were they thinking?  OK, new business).
    Back then, I happened upon a set of routines in something called
    Aclyutil.arx (downloaded it from somewhere) that included
    PAGEOUT.  This routine would take all the stuff you
    filled in those 20 or 30 windows and radio buttons in the AutoCAD Plot
    Dialog Box, and write it all to a groovy little Script file that looked
    something like this:
    ._TILEMODE 0
    (setq expert (getvar
    "EXPERT"))(setvar "EXPERT" 2)
    ._-PSETUPIN
    "C:\Program Files\AutoCAD
    2000i\Drawing1.dwg"
    "E-1055bw-fullsize"
    (setvar "EXPERT"
    expert)
    ._-PLOT
    _No
    E-1055bw-fullsize
    size=2>_No
    _Yes
    _No
    You could then run one of a bunch of these Scripts
    from a Pulldown Menu full of command lines like:
    [HP 1055 BW -
    Fullsize]^c^cTilemode;0;Ltscale;.5;SCRIPT;E-1055bw-fullsize;PLOT;
    I was very happy for about a year and a half until
    I started using Acad2002 this month.  I can't seem to get those scripts to
    work anymore.  I might be missing something obvious, But I'd rather assume
    that AutoDesk stumped me with some variation of the order of the command line
    steps that used to work fine in Acad2000 and Acad2000i.  (Either that or
    they dumped another "command line option" for some command this script
    uses.)
    Anybody out there using
    Aclyutil.arx's Script Files with any success on
    Acad2002?
    Can anybody find the errors in this process
    (relative to Acad2002)?
    Please use plain text.
    *Payne, John
    Re: Aclyutil.arx still work?
    09-29-2001 01:31 AM in reply to: *Wojtynek, Steve
    Maybe not the answer you were looking for, Steve,
    but immediately springing to mind is a scenario where
    you run the script a line at a time at the command line
    until you get an error message...and adjust it
    until it completes.
    You can then scroll back thru the successful command
    line interpretations using up arrow...copying and pasting
    them back into the script.
    As it's entered in your e-mail...is that the way it comes
    in the utility? Some of the lines need to be combined into
    1.
