• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Express Tools
    *Matt
    ABS 2007
    139 Views, 2 Replies
    04-26-2007 08:21 AM
    Hi
    i had problem with my buidling systems 2007, so i had to reinstall it, after
    reinstallation done, my express tool is missing, of course the next course
    of action is to go to add/remove program, try to chnage/modify ABS 2007, &
    then select express tool, on your option window to install it again, but in
    my case it says that express has already been installed, & there is a folder
    under ABS2007 for express, i tried to do a search for acetmain.cui or mnu, i
    found it, by using menuload command i loaded it, but it does not do any
    thing, by looking at the file size & comparing to the other cui, this is
    only 1 kb, meaning this is a blank file.
    so how can i get my express tool back?
    Matt
    Please use plain text.
    *Matt
    Re: ABS 2007
    04-27-2007 09:04 AM in reply to: *Matt
    Finally, i got my tool bars back & they are working fine, but icons are
    missing, express folder is in my support path, any suggestions?
    "Matt" wrote in message
    news:5565450@discussion.autodesk.com...
    Hi
    Matt
    New Member
    Re: ABS 2007
    06-02-2007 05:21 PM in reply to: *Matt
    I have noticed that most of the items that were in express tools are now part of 2007 menu. It is under pulldown Format/Layers.
    Hope this helps.
