• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    *Dave Drahn
    2010 ET Tframes not toggling
    2063 Views, 7 Replies
    03-10-2010 02:17 PM
    TFRAMES command in 2010 doesn't seem to toggle
    image frames.  It just continuously turns them off.  Anyone else
    notice this or is it just me?
    Please use plain text.
    *Dean Saadallah
    Re: 2010 ET Tframes not toggling
    03-11-2010 05:59 AM in reply to: *Dave Drahn
    It's old and no longer useful: FRAME system variable, usage explained in
    HELP in 2010. A little lisp and you can get it to toggle as you wish.
    If you want to use this with Wipeouts, lisp is your friend too.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    *Dave Drahn
    03-11-2010 02:07 PM in reply to: *Dave Drahn
    Thanks Dean.
    Problem is we've temporarily got people on 2008 and 2010 and one of our
    shortcuts simply runs TFRAMES toggle (in 08). That's still available in
    2010 but apparently doesn't work right so I modofied the macro to
    (if (= (getvar IMAGEFRAME) 0)
    (setvar IMAGEFRAME 1)
    (setvar IMAGEFRAME 0)
    as a toggle. But that doesn't work in 08 because IMAGEFRAME is a command in
    08 but not a variable. Now looks like IMAGEFRAME (and as you point out,
    also FRAME) is a var in 10 but not 08. So I may be able to use a command
    toggle for both but can't simply test for the current var value the same way
    in both anymore....
    Not a huge deal, just have 2 macros now for it in the transition. An
    inconvenient bug I think.
    "Dean Saadallah" wrote in message
    news:6352902@discussion.autodesk.com...
    > Dean Saadallah
    *Dean Saadallah
    03-12-2010 05:53 AM in reply to: *Dave Drahn
    You can lisp "something new" called TFRAMES if that makes everyone happy, in
    both programs.
    Don't let a command name be the only thing holding you back from using the
    program the way you want: it's the reason you dropped a ton of money on it.
    Dean Saadallah
    *Dave Drahn
    03-12-2010 03:33 PM in reply to: *Dave Drahn
    no duh.
    just trying to easily get the same thing to work in both versions. TFRAMES
    is apparently still a command in 2010, it just doesn't work correctly.
    news:6353755@discussion.autodesk.com...
    > in both programs.
    > it.
    > Dean Saadallah
    *Dave Drahn
    03-18-2010 01:15 PM in reply to: *Dave Drahn
    Great.  Now it seems that the IMAGEFRAME var
    in 2010 (not a var in 08) does not control wipeout frames...
    style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px"
    dir=ltr>
    "Dave Drahn" <ddrahnATpacewaterDAHTcom> wrote in message
    href="news:6352569@discussion.autodesk.com">news:6352569@discussion.autodesk.com
    *Dean Saadallah
    03-22-2010 02:33 PM in reply to: *Dave Drahn
    ET development stopped a while back.
    Dean Saadallah
    sonablue
    06-07-2011 11:42 AM in reply to: *Dean Saadallah
    Restarting AutoCAD seems to bring the TFRAMES toggle back to life.
    -Sona
    Allisona Greenberg | SAIC Energy, Environment & Infrastructure, LLC
    Landscape Architect & CAD Manager | Water, Environment & Transportation
