• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    Member
    2002 Express tools Revision Cloud
    98 Views, 3 Replies
    11-19-2002 07:46 AM
    Does anyone know how to make the Revision Cloud button to be it's own separate button so I can dock it in a permanent on screen toolbar other than the toolbar it is on. I've tried everything I can think of. Thanks
    Please use plain text.
    Distinguished Contributor
    Re: 2002 Express tools Revision Cloud
    11-19-2002 08:27 AM in reply to: juanh
    Tools-->Customize-->Toolbars-->Commands tab, pick "User defined" from the Categories list. from the Commands list on the right, click and drag "User Defined Button" into the drawing window (this will create a toolbar with a single button.) right click on the REVLOUD button, select "Copy Button Image" and paste it into your new button. with the customize window still open, click once on the original REVCLOUD button to open its button properties and copy and paste the name, description and macro into your new button. (NOTE: the new toolbar will, by default, be placed in the ACAD menu group. if you want to associate the toolbar with a different group, just create a blank toolbar under the selected group and drag the "User Defined Button" into the toolbar.)
    *pkirill
    11-20-2002 01:15 AM in reply to: juanh
    Here's another tip - create your own personal menu group first. There are
    good instructions for this in the help files. Basically create a file in
    notepad called MYMENU.MNS (where "mymenu" is whatever you want). In that
    file put this: ***MENUGROUP=MYMENU Then load it like you would any other
    menu. Now when you follow dviator's instructions select MYMENU as a menu
    group, not ACAD. IMHO, it's never a good idea to muck with the standard
    AutoCAD menus. It's been known to have a domino effect that can screw up
    all your menus...
    "juanh" wrote in message
    news:f125298.-1@WebX.maYIadrTaRb...
    *Healy, Patrick
    11-27-2002 12:18 AM in reply to: juanh
    yeah, cool. customize toolbars, shift drag and drop onto your main toolbar!
