• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    gbains
    wire reference issues
    132 Views, 1 Replies
    12-16-2011 07:27 AM
    I can't seem to have line reference wire numbers on my ladder. I set it in the project settings to 1,2,3 but the numbers remain the same as the first line number. Any suggestions ?
    Please use plain text.
    Re: wire reference issues
    12-17-2011 11:19 AM in reply to: gbains
    I'm not sure if this is the issue or not, but the wire number doesn't change through node dots.  It will change once you insert symbols onto a rung but it will only change on the side of the symbol that is opposite the ladder rail (bus).  See attached screen capture.  I'm just guessing since I haven't seen your drawing, but this can sometimes be confusing for new users of ACE.  The line reference-based wire numbers can only start if the is a component separating the rung from the rail (bus).
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
