• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Accepted Solution
    wire/layer relationship
    123 Views, 1 Replies
    12-07-2011 07:40 AM
    still trying to export/import wirelist from electrical to inventor. 2010 tutorials are lacking.
    i WAS able to export list from electrical. During import nothing seems to happen, but, when checking the xfer log all wires are on a layer that is not (compatible) in Inventor.
    I dont understand the relationship entirely. I created the layer in electrical (from scratch) and changed all wires to be on that layer. I dont see how to select a library layer, one that is already acceptable so I created a similar layer in Inventor.  When i import i am not asked to relate the layers, that is to show (electrical) where i created the layer in Inventor.
    What really needs to be done here. Say i have my completed schematic in electrical.......
    How do i create a layer in electrical that the program will like? How do i get at library (established) layers?
    How do i create the same layer in Inventor so that both programs see it.
    Tim Moxam - Senior Mechanical Designer
    Windows 7 64 bit
    Inventor 2012 Professional
    Dell T1600 CPU E31245 @ 3.30GHz
    8 GB RAM
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    Re: wire/layer relationship
    12-08-2011 01:31 AM in reply to: tmoxam
    Hi.
    When you created a layer in AcadE, did you use the "Create/Edit Wire Type" command?
    What's important, is that the wire types you create in AcadE (i.e. the layer name), must match the name of a wire type in Inventor. If you don't have a matching wire type in Inventor, you can create it in a couple of ways.
    1. On the fly in the "Import Harness data"-dialog, by right-clicking the missing wire (BLACK_2.5mm2) in this picture, and select "Add to Cable & Harness Library".
    2. Open the Cable & Harness Library, and add the wire type manually. The NAME of the wire type must match the layer name of AcadE's Wire Type.
    Hope this is helpful.
    THL
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
