• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Contributor
    wire cross
    95 Views, 3 Replies
    06-21-2004 11:12 AM
    When I select solid for wire crossing in the dwg configuration and close dialog box, then insert a wire crossing another wire I am still getting the loop. When I check the drawing configuration, it has reverted back to the loop setting for wire crossing. Is this a bug or am I missing something?
    thanks for any response.
    Please use plain text.
    *Nate Holt \(Autodesk\)
    Re: wire cross
    06-22-2004 06:48 AM in reply to: lauraw
    Are you dismissing the dialog by hitting the "X" in the upper right hand corner of the dialog or by hitting "OK" button? If you're hitting the "X" to dismiss the dialog, I believe this is being treated the same as if you'd hit "Cancel" and the configuration change is not saved. Let me know... thanks! Nate. "lauraw" wrote in message news:17559549.1087841586951.JavaMail.jive@jiveforum2.autodesk.com... > When I select solid for wire crossing in the dwg configuration and close dialog box, then insert a wire crossing another wire I am still getting the loop. When I check the drawing configuration, it has reverted back to the loop setting for wire crossing. Is this a bug or am I missing something? > > thanks for any response.
    Active Contributor
    Re: wire cross
    06-23-2004 07:50 AM in reply to: lauraw
    thank you nate... guess I was having a brain... you know what...
    Could have sworn I selected ok in past attempts!!!
    working properly now!!!!
    New Member
    Re: wire cross
    07-17-2007 11:56 AM in reply to: lauraw
    Does anybody know how I can configure AutoCad Electrical to have wire loops with the size I set?
