• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    .wda File Question
    202 Views, 5 Replies
    01-19-2007 12:22 PM
    Is there a default name that can be given to the User Defined Attribute List file (.wda) so the file does not have to have the same name as the project. I want to be able to use the same file for each project without having to rename the file to match the project. Similar to the way the Title block mapping file works (default_wdtitle.wdl).
    Is this possible?
    Please use plain text.
    Distinguished Contributor
    Re: .wda File Question
    01-22-2007 12:01 AM in reply to: Hedivan
    found in the electrical help:
    default.wda
    Sven Kloeck
    Electrical Network Design
    Active Contributor
    David_S_Barrow
    09-06-2011 12:59 AM in reply to: sven_kloeck
    Can you place the default.wda in a central location so that it is relevant to all network users?
    09-06-2011 07:07 AM in reply to: David_S_Barrow
    Place it in your User folder.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    Valued Contributor
    01-29-2013 09:58 AM in reply to: Hedivan
    Hi All,
    I've been trying to use the method described above. It is working just fine on a project by project basis, but I have set up a default.WDA file to use for all projects and saved it on our network under USER but no results. Another post says to save this file at the base project location - where would that be?
    Any help would be greatly appreciated.
    Mike
    Valued Contributor
    Nata_ly
    01-29-2013 11:47 PM in reply to: flyFisher67
    Try to do next:
    1. Put default.wdl and default.wda to your network.
    2. Find all default.wdl and default.wda on you computer and rename they (ex. default1.wda)
    3. Make sure there are no <projectname>.wdl and <projectname>.wda files too
    4. Open Options in ACE and choose tab Files line Support File Search Path. Add there your path to the default.wda from network.
    5. Repeat the same on all computers in your office to make them use this files from network
    This works for sure with default.wdl and I hope could work with default.wda too.
    If this files are only for your use - put they into Suport folder or any other folder but add the path.
