• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Distinguished Contributor
    wd_dinrl
    284 Views, 6 Replies
    06-17-2008 12:37 PM
    Hey Nate. Is there some way we can get the wd_dinrl api modified so it will add the attribute "LENGTH" and automatically enter the length of the rail or duct being created? Currently you are adding Rating1 and Rating2 but by adding the Length we could then include that in our BOM reports.
    We are currently using ACADE 2008.
    Thanks.
    Please use plain text.
    Re: wd_dinrl
    06-26-2008 04:02 AM in reply to: sgsawdy
    Anyone home?
    *Pat Murnen
    Re: wd_dinrl
    07-07-2008 06:56 AM in reply to: sgsawdy
    When the Din Rail is drawn in, AcadE adds the attributes from the block
    wd_ptag_addattr_comp.dwg. This is where the RATING attributes come from. You
    can add the LENGTH attribute to this block if you want. That means that the
    LENGTH attribute will be added on any panel component though (excluding
    panel terminals). No value would be added but when the Insert/Edit dialog
    comes up you can select Show/Edit Miscellaneous and add a value. Not exactly
    what you were looking for but works without any programming updates.
    Pat Murnen
    wrote in message news:5959606@discussion.autodesk.com...
    Thanks.
    Re: wd_dinrl
    07-07-2008 07:04 AM in reply to: sgsawdy
    Thanks for getting back to me on this Pat. I wound up creating a lisp routine to add the attribute and the length once the din rail or wire duct is drawn. I will attach it in case it can be useful to anyone else.
    How it works is after you are done drawing your din rail or wire duct you have to launch the lisp routine, pick the block you want to add the length attribute to and then pick the endpoint of the same block. This measures the distance from the startpoint to the endpoint you picked and places that value in the LENGTH attribute it adds to the block.
    Is it possible to have this added to the wish list for future releases?
    Scott
    *Pat Murnen
    Re: wd_dinrl
    07-07-2008 08:03 AM in reply to: sgsawdy
    I can log this. Basically you want a way to have the length of the dinrail
    added to the block as it is built and then have it reported in the Bill of
    Materials report. I am assuming that if you have multiple pieces of the same
    catalog type din rail that you would want the report to add the lengths
    together.
    Remember, logging an item only means that it will be considered for a future
    release.
    Pat
    wrote in message news:5974736@discussion.autodesk.com...
    block.
    Scott
    Re: wd_dinrl
    07-07-2008 08:11 AM in reply to: sgsawdy
    That is exactly what we want Pat.
    Isn't that why it is called a "wish list".
    Scott
    New Member
    Re: wd_dinrl
    11-09-2012 12:57 PM in reply to: sgsawdy
    I ran the lisp file and it added the length attribute. Is there a way to get this info into the BOM quantity?
