• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    upgrade autocad 2012 to autocad electrical 2012
    217 Views, 3 Replies
    03-14-2013 06:55 PM
    I have autocad 2012 installed on my machine. I want to upgrade it to autocad electrical 2012. what should I do?
    Is it entirely a different programme or an upgrade of autocad?
    Should I download the whole programme (which is almost 3gb in size) or I have to install any upgrade?
    If so plz guide me how can I upgrade my software?
    Please use plain text.
    Customer Service
    joane.bonghanoy
    Re: upgrade autocad 2012 to autocad electrical 2012
    03-14-2013 08:06 PM in reply to: waseem038
    Hi waseem038,
    AutoCAD is a totally different Product from AutoCAD Electrical. If you want to install AutoCAD Electrical, you would need to download it.
    You mentioned that you want to install the 2012 version? Are you trying to download this from Subscription Center or from the Education Community Site? Do you have an AutoCAD Electrical Serial Number?
    Joane Bonghanoy
    AutodeskHelp | Customer Care Representative
    TW | PI | YT | BLOG
    New Member
    03-14-2013 08:18 PM in reply to: joane.bonghanoy
    Thanx Joane
    No i dont have a serial number yet.   I just thought that autocad electrical is an upgrade to autocad.  And I have autcad 2012 installed on my system, so was thinking to upgrade it. but now I will have to dowload it from as educational free trial.
    Distinguished Mentor
    03-14-2013 10:03 PM in reply to: waseem038
    Talk to your local re-seller. You should be able to buy an upgrade to go from ACAD to ACADE for a significant saving over buying the full ACADE package.
    You may also be able to get a test drive version to see if it will suit your needs.
    If you go the Educational version, be aware that all dwgs will have a non removable watermark stating that it was created or modified using it.
    A similar question was asked within the last week or so and is basically the same answer as I've given.
    http://forums.autodesk.com/t5/AutoCAD-Electrical/AutoCAD-to-AutoCAD-upgrade-available/td-p/3801208
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
