• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Contributor
    txt2mtxt command
    1499 Views, 5 Replies
    07-26-2012 12:41 PM
    Just got upgraded to Electrical 2013. my favorite text command is no longer useful. That is the "txt2mtxt" command....I need this back!...Any other commands like this?
    Please use plain text.
    Valued Contributor
    Tee.Dee
    Re: txt2mtxt command
    07-26-2012 03:44 PM in reply to: pseguy2007
    It may or may not be obvious but do you have the express tools loaded?
    Employee
    RobinShou-Autodesk
    07-26-2012 10:21 PM in reply to: pseguy2007
    This is a known issue for ACE2013, we are working on the fix for it now.
    Please refer to the workaround in the following link for now:
    http://www.youtube.com/watch?v=952RR_h0HhI&feature=player_embedded
    Robin Shou
    Quality Assurance
    AutoCAD Electrical
    Autodesk, Inc.
    SGY
    Active Member
    SGY
    08-01-2012 02:10 PM in reply to: RobinShou-Autodesk
    I am having the same problem of some express tools not working in Structural Detailing, 2013. Your tip of manually loading LEADEREX.ARX also works for Autocad Structural, 2013.  Great tip, thank you.  I hope Autodesk fixes this problem.
    New Member
    12-28-2012 01:02 PM in reply to: pseguy2007
    Hi pseguy2007,
    I am working in AutoCAD MEP 2013 and the command didn't work in there but it worked in regular AutoCAD 2013. After more research I found that the command is in leaderex.arx and is not a Lisp Routine. Load it (leaderex.arx) into your AutoCAD Electrical 2013 using the appload command while you are in a drawing. Make sure you add it to your History folder and add it to the contents of your Startup Suite as well. Save and close the drawing and AutoCAD. Now it should be working when you reopen AutoCAD.
    The Express folder should be located here: C:\program files\autodesk\autocad 2013\express
    Let me know if that helps.
    New Member
    12-28-2012 01:03 PM in reply to: RobinShou-Autodesk
    Is the fix in Service Pack 1?
