• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    april_herr
    Re: titleblock set up
    10-04-2011 10:36 AM in reply to: rhesusminus
    Thank you, that absolutely did work!  Norway? Awesome!:smileyvery-happy:
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    10-04-2011 11:56 AM in reply to: april_herr
    Yeps. Norway. It's getting colder now, but I could still fire up the bbq for dinner :smileyhappy:
    Please feel free to use the kudos buttons, and set the post to "solved" :smileyhappy:
    THL
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
    Valued Contributor
    10-04-2011 11:58 AM in reply to: april_herr
    A nested block is usually not recommended as it "hides" attributes.  How they are created is typically by making a block in a drawing, inserting the drawing as a block into another drawing.  Because you have already created a block in the drawing being inserted as a block you will have nested blocks.
    The only time I use nested blocks is when I DO NOT want the attributes to be accessible.  That is usually related to when I have multiple identical blocks but only want one block to feed information to my reports.  Especially useful when presenting mutiple views of a 2D block like an enclosure where each view has pre-defined catalog information.
    Scott
    Scott G. Sawdy
    scott.sawdy@bluecoyotecad.com
    april_herr
    10-04-2011 12:08 PM in reply to: april_herr
    One more question:  I have my block set up in model space with my WD_TB file associated with it.  But when I try to input info, it reads backwards.  I checked my wd_tb file and it reads fine.
    april_herr
    10-04-2011 01:28 PM in reply to: sonny3g
    Thank you for explaining nested blocks.  I will keep this in mind for the future:smileyhappy:
    rhesusminus
    10-04-2011 02:04 PM in reply to: april_herr
    I'm not completely sure what you mean here. The file APRILS_TEST.txt semms to be a *.WDL-file (that sets the decription labels for the project), and it has nothing to do with the WD_TB attribute... well.. unless your problem shows up when running title block setup?
    THL
    THL
    april_herr
    10-04-2011 02:14 PM in reply to: rhesusminus
    Ok, I am completely confused!  I thought I the text file was my WD_TB.  When I ran the setup the first time, it kept saying my attribute was missing when I ran the update.  But when I do the set up again, I go in order, and the same thing happens where it is backwards.  I apologize for so much confusion!  But I do appreciate your time and help:smileyhappy:
    Where does that text file come into play?
    10-04-2011 02:24 PM in reply to: april_herr
    That text file you posted is the descriptors for the various lines in the Project Description Dialog box. This information will replace Line 1 with Job NO, Line 2 with Cust, etc. It need to be renamed to default_wdtitle.wdl to work properly.
    Here is a wiki that explains how to set it up:  http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2011/Help/User's_Guide/115Project-WideTools/1399...
    Bob Hanrahan
    Bob Hanrahan
    Ace User since 1998
    april_herr
    10-04-2011 02:48 PM in reply to: testsubject
    I read through that very helpful link, followed it to a 'T' and my titleblock is still going backwards.  The order that I clicked on each attribute, is backwards.  If I look at the WD_TB it lists the attributes in the correct order.I also redid my txt file as per your instruction.  Thank you very much for your help!
    April
    rhesusminus
    10-04-2011 03:15 PM in reply to: april_herr
    I think I know what you mean now.. You mean the order the attributes appear in, when you double-click the title block, right?
    In this case, use the BATTMAN command in AutoCAD. Select your title block (in the DWT-file of course), and use the Move Up/Down buttons to move the attributes to whatever order you want them to be in.
    THL
    THL
