AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
terminal associatio n confusion
- Highlight
- Email to a Friend
- Report Inappropriate Content
I typically use AB 1492-L3 and 1492-L3Q terminals and want to associate them or whatever's needed to try and accurately track how many terminals i need. The L3 terminals have 2 wire openings total (1 per side), and the L3Q terminals have 4 total (2 per side). I'd like for ACADE to be able to figure out how many terminals I need, based on the number wire connections (with dots) and terminals with a given wire number used throughout the project. It seems that if I'm using the L3Q terminals, I would configure the terminal block properties as 2 levels with 2 wire connections for each level, and that the levels should be jumpered together. It seems I can only associate 1 termination per level though, does that make sense? If I want to be able to terminate 4 wires per terminal (since it has 4 wire termination points), do I have to list the L3Q terminal as a 4 level terminal, with all levels jumpered together?
Re: terminal associatio n confusion
- Highlight
- Email to a Friend
just bumping this in case anyone has suggestions...
i saw other posts that use 4 levels for a 1492-L3Q terminal with 1 wire connection per level, but I'm not sure how to check that the Terminal Strip Editor is correctly catching all the connections the DOT is making when it connects a wire to a common ladder bus.
thoughts?
