• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Dan.M
    Accepted Solution
    scale components after insert
    223 Views, 4 Replies
    12-17-2012 02:13 AM
    How can I scale up only the electrical blocks in the scheme.
    They came out a little bit small. i work with Eletrical 2013
    Dan
    Please use plain text.
    Valued Contributor
    Nata_ly
    Re: scale components after insert
    12-17-2012 05:14 AM in reply to: Dan.M
    Sware/Update block - Option B - Update a block - Choose scale. Is this you are looking for?
    Dan.M
    Thank you.  Dan
    12-17-2012 11:16 AM in reply to: Nata_ly
    Thank you.
    Dan
    Active Contributor
    12-17-2012 12:02 PM in reply to: Nata_ly
    I want to make a small comment on your answer. Where the command is, or what it actually is would be helpful for those of us new to Electrical. I had to use the help command to find the following:
    Ribbon:  Schematic tab  Edit Components panel  Swap/Update Block.
    Toolbar: Insert Component
    Menu:  Components  Component Miscellaneous  Swap/Update Block
    Command entry:  AESWAPBLOCK
    Just an FYI
    Distinguished Mentor
    12-17-2012 02:31 PM in reply to: jdonaldson3
    Try swapping your block library. From the looks of the screen capture, you are using a smaller library than required for the sheet size.
    For example, you might be using IEC2 when for the sheet size, you may need to be using IEC4. The only differrence between the two libraries is the scale of the inserted blocks.
    To swap a library, go to the Swap/Update block tool and in section 'B' choose the second option. Choose the appropriate library and let the tool run.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
