• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Valued Contributor
    "Smart" wire color/gauge label
    104 Views, 5 Replies
    12-04-2003 12:23 AM
    When I put a wire color/guage label on a wire,
    the label does not update if I change the
    layer of the wire. Do I need to use an update
    utility to have the label reflect the new wire
    layer?
    Lynne
    Please use plain text.
    Valued Contributor
    Re: "Smart" wire color/gauge label
    12-04-2003 12:26 AM in reply to: Lint
    Also, the wire selection does not carry over
    the loops.
    *Autodesk, Inc\
    Re:
    12-04-2003 12:49 AM in reply to: Lint
    Lint
        Are you using Electricals' WIRE
    LAY utility or just using general AutoCAD commands to modify the layer?  If
    you use the WIRE LAY utility, it will change the layer of the entire "wire" and
    not just the one selected line segment.  Also, using this utility will
    force the wire color/gauge labels to update.  This command can be found on
    the pull down menus' at:
    ELECTRICAL > WIRING MISC > WIRE
    LAYERS
        I hope this helps!
    Sincerely,
    Jared Bunch
    Technical Support Specialist
    Autodesk, Inc
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Also,
    the loops.
    *Autodesk, Inc\
    Re:
    12-04-2003 12:50 AM in reply to: Lint
    Sorry.....using general AutoCAD functions will not
    do all of this work for you.
    Lint
    WIRE LAY utility or just using general AutoCAD commands to modify the
    layer?  If you use the WIRE LAY utility, it will change the layer of the
    entire "wire" and not just the one selected line segment.  Also, using
    this utility will force the wire color/gauge labels to update.  This
    command can be found on the pull down menus' at:
    LAYERS
        I hope this
    helps!
    Sincerely,
    Jared Bunch
    Autodesk, Inc
    Also,
    the
    loops.
    Valued Contributor
    Re:
    12-04-2003 04:54 AM in reply to: Lint
    Yes, that helps! thanks.
    Is there a central place where I can set the
    test height and move the label a set distance off the wire?
    It seem like I have to reset this on each drawing.
    Lynne
    *Autodesk, Inc\
    Re:
    12-04-2003 05:39 AM in reply to: Lint
    Lint
        The settings for the Wire/Color
    Gauge label are just like the drawing config settings, they are held on each
    individual drawing.  If you are modifying these settings, you would want to
    do this in your template file so that you do not have to modify each drawing
    that you create.  When you use leaders, you can specify with the placement
    of the leader how far it is from the wire.  If you place them without
    leaders or use the auto-placement, you must adjust the spacing after they are
    inserted.  I hope this helps to give some insight.
    Sincerely,
    Jared Bunch
    Autodesk, Inc
    Yes,
    that helps! thanks.
    test
    It seem like I have
    Lynne
