• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Accepted Solution
    panel BOM and adding Company part# (modifed pur_pbom.set)
    161 Views, 3 Replies
    10-30-2012 06:29 AM
    Hi All,
    I am trying to add our company part # to the BOM.
    I added the attribute (NER#) to the panel symbol
    I run it from projects/reports/panel reports/ Bill Of Material.
    I have modifided the PUR_PBOM.SET to include the following
    under title...NER#
    under characters...5
    under justification..."L"
    i added all of these at the end of all the others under those headings
    In the report i can select to add the column (NER#) to the report and it comes up but with the wrong info.(the value is 98765 but it shows up as 101)
    Any 1 have an idea what I am doing wrong???
    Attached is the file with my changes in red
    Thanks in advance for any help
    Dennis
    Please use plain text.
    *Expert Elite*
    Re: panel BOM and adding Company part# (modifed pur_pbom.set)
    10-30-2012 06:36 AM in reply to: acade2012
    I am not sure if what you are trying to do would work, but there is an easier way.
    In the Catalog Database, there are 3 USER fields for our use (USER1, USER2,USER3). I use USER1 for my internal (company) part numbers.
    After filling these out in the database, I then just added USER1 to the report ( I renamed it "Company P/N"), and the info was readily available.
    I hopoe this helps.
    Bob Hanrahan
    Ace User since 1998
    Valued Contributor
    10-30-2012 06:40 AM in reply to: testsubject
    Thanks Bob,
    I knew I could do it that way.
    I guess I am just a glutten for punishment and was trying to...
    1) better understand how the BOM reports work.
    2) get it to work (too much time on my hands)
    again
    Valued Contributor
    10-30-2012 07:02 AM in reply to: acade2012
    Bob,
    I took your advice and made it work.
    In playing with it a little more I made it so the only change from the original pur_pbom.set is the heading which I changed from user1 to NER#.
    everything works fine
    thanks for the help
    Dennis
