• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    marker fan in/out source or dest
    59 Views, 2 Replies
    03-29-2004 06:23 PM
    I been trying to figure out how to use this feature with little success. I been putting in the source and destination points with little trouble. The problem really happens when putting in the wires going into the multi-conductor cable. If I use the regular wire tool it wants to put in a connection point.
    Please use plain text.
    New Member
    Re: marker fan in/out source or dest
    03-31-2004 10:17 AM in reply to: bruen
    I aslo have had this same problem. Let me know if you come up with anything. I will do the same
    03-31-2004 10:52 AM in reply to: bruen
    I have only used this tool on a couple of projects and here is what I have found about how it works. You have to use the AutoCAD LINE command to begin your "wire" fan in/out geometry, up to the point where the fan in/out wires would be horizontal or vertical to connect to your device. Use the Wire Tool for completing the circuit wiring to the device.
    Now insert your fan in/out Source & Destination symbols. Then use the Markers - Fan in/out - Layers Toolbutton to assign the basic geometry to the "_MULTI_Layer" layer.
    This is how it has worked best for me. A lot of steps but it works. Maybe the pros with speak up and give us some clues. Hope that helped.
    Jim
    Mckee Foods Corp.
