• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Member
    oveimariemamn
    line chickness
    59 Views, 1 Replies
    01-30-2012 11:55 PM
    When i draw lines with the Line-command all lines shows in the same chickness, would it be possible to show the different chickness on the screen when drawing lines with Line-command and not only when printing?
    Active Member
    Skiflea
    Re: line chickness
    01-31-2012 06:47 AM in reply to: oveimariemamn
    You can go to the AutoCAD 'Options' dialog and select the 'User Preferences' tab.  On there select the 'Lineweight Settings' button.  On the dialog that appears, toggle ON the 'Display Lineweight' option.
    Steve
