• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    JRitz
    language conversion
    103 Views, 3 Replies
    10-18-2011 07:12 AM
    I have a set of e-plan drawings that I need to convert from German to English.  Is this possible if I pull them into a AutoCad Electrical project?  I would have thought if the eplan used attributes it would work, but so far it is not.  Any suggestions?
    *Pro
    Re: language conversion
    10-30-2011 11:26 AM in reply to: JRitz
    EPlan runs on a proprietary database platform.  There is no direct conversion possible.  AutoCAD Electrical is the only software of its type that stores that component data in AutoCAD's native attribute format.  This is one of the advantages of AutoCAD Electrical.  Anyone with a .DWG reader can see the data by viewing the attribute values within the symbols.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    www.ECADConsultant.com
    Distinguished Contributor
    02-02-2012 08:51 AM in reply to: dougmcalexander
    Is there perhaps any third-party software, or company that could convert between the two?
    We have some schematics drawn in Germany in E-Plan that need to be worked on over here in our US office, which does not have E-Plan.
    Any thoughts?
    *Pro
    02-02-2012 10:54 AM in reply to: scottgensemer8984
    You can take a DXF file from EPlan and use the tools on the conversion menu tab within AutoCAD Electrical to convert the blocks in the DXF file to equivalent AutoCAD Electrical blocks.  The Block Replacement tool is an automated way to handle this, once you set up the mapping spreadsheet.  You can even convert the lines that represent wires to actual wires.  You can also convert  text entity to a wire number.  There are many options on the conversion menu tab for converting everything from dumb graphics or blocks from other software so they work within the AutoCAD Electrical editing environment.  You can save them as DWG files or DXF them out again.  This is one of the subjects we cover in my advanced training course.
    Doug McAlexander
