• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    insert wbcircuit problem.
    80 Views, 2 Replies
    07-03-2012 11:39 AM
    Everytime i try to insert a WBCIRCUIT under the schematic tab or with the command "AEWBCIRCUIT" usually a dialog box pops up and I can browse all my saved circuits. This is what the "Help" feature also tells me to do (F1). But everytime I use it now, it prompts me for the block name. Simular to when I create a block. This is what the command line gives me.
    Command: aewbcircuit
    Insert WBlocked Circuit
    _.UNDO Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
    Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
    <1>: _MARK
    Command: _.UNDO Current settings: Auto = On, Control = All, Combine = Yes,
    Layer = Yes
    <1>: _BEGIN
    Command:
    "Block name:"
    Maybe I have a setting wrong but I can't seem to figure it out. On one of our other Steats it works and the Command promt looks like this when its working:
    WD_M insert: C:\Users\Public\Documents\Autodesk\Acade 2011\Libs\jic125\WD_M.dwg
    <1>: _MARK
    Layer = Yes
    <1>: _BEGIN
    Although, my seat doesn't indicate
    "WD_M insert: C:\Users\Public\Documents\Autodesk\Acade 2011\Libs\jic125\WD_M.dwg"
    after inputing the command.
    Does anyone have an idea of what to do?
    Thanks!
    James
    Please use plain text.
    Valued Contributor
    Tee.Dee
    Re: insert wbcircuit problem.
    07-04-2012 07:42 PM in reply to: backcountryjame
    You could try this:
     In the command line type in FILEDIA then press enter then enter a value of 1 and try the the AEWBCURCUIT command again.
    Let us know if that works.
    Tim
    Member
    07-05-2012 08:26 AM in reply to: backcountryjame
    works great - i really appriciate the help.
