• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    error:no function definition: ACE_GETACTIVEPROJECT
    256 Views, 14 Replies
    01-17-2013 12:00 PM
    I recently installed AutoCAD Electrical 2012 on my Computer, and everytime I try to insert a wire or any other component the following message pops up on the command line:
    error: no function definition: ACE_GETACTIVEPROJECT
    any ideas on how to resolve this issue?
    Please use plain text.
    Valued Contributor
    Re: error:no function definition: ACE_GETACTIVEPROJECT
    01-17-2013 06:27 PM in reply to: micruiz
    Did you check your support file search path is correct in the Options, File tab?
    Try to use the deafult button to reset the path if not.
    Thanks.
    Active Member
    01-17-2013 08:09 PM in reply to: lionSG
    I looked at the Support File Path, and this is what I got:
    C:\program files\autodesk\acade 2012\acade
    C:\users\public\documents\autodesk\acade 2012\support\
    C:\Users\ironmangko\appdata\roaming\autodesk\autocad electrical 2012\r18.2\enu\support
    C:\program files\autodesk\acade 2012\support
    C:\program files\autodesk\acade 2012\fonts
    C:\program files\autodesk\acade 2012\help
    C:\program files\autodesk\acade 2012\express
    C:\program files\autodesk\acade 2012\support\color
    C:\Users\ironmangko\documents\acade 2012\
    C:\Users\Public\Documents\Autodesk\Acade 2012\Libs
    Valued Contributor
    01-17-2013 08:59 PM in reply to: micruiz
    The search paths look ok.
    Try the project settings tab, check that the Schematic Icon Menu File is pointed correctly to the library that you use
    For IEC, ACE_IEC_MENU.DAT.
    Thanks.
    Active Member
    01-17-2013 09:40 PM in reply to: lionSG
    I tried that, but it kept reverting back to this file:
    ace_jic_menu.dat
    Valued Contributor
    01-17-2013 09:59 PM in reply to: micruiz
    Click on the path and browse to the correct ACE_IEC_MENU file.
    It should be in your user profile\appData\roaming\autodesk\ACAD Electrical\release\enu\Support folder.
    Also check that your schematic libraries are also changed from the JIC to the IEC libraries for the oneline circuit /1-/ as well.
    Active Member
    01-17-2013 10:37 PM in reply to: lionSG
    I did that and clicked ok. However, it reverted to the previous file again.
    Valued Contributor
    01-17-2013 11:26 PM in reply to: micruiz
    Did you install and select the IEC symbol library when you first installed the ACE?
    Goto the Add/Remove program and check again.
    Try to delete the lastproj.fil in your roaming support user folder, the file could be corrupted.
    Active Member
    01-18-2013 07:53 AM in reply to: lionSG
    I tried to uninstall and reinstall it without the jic symbol library, and when I opened  it, I still couldn't change it the Schematics Icon Menu Wizard.
    Valued Contributor
    01-20-2013 06:42 PM in reply to: micruiz
    I suspected you may have a existing JIC format drawing opened.
    Try to open a new drawing or project and see if it worked anot.
    Thanks.
