• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    Re: error:no function definition: ACE_GETACTIVEPROJECT
    01-22-2013 10:57 AM in reply to: lionSG
    I tried that but it still not working. Now when I try to insert a wire or any other component the following message pops up:
    "file not found: ace_jic_menu.dat...
    ...the file may be related to undefined environment paths in wd.env: WD-PROJ -- default path to project files"
    Please use plain text.
    Valued Contributor
    01-22-2013 05:42 PM in reply to: micruiz
    Are you pointing to a network share folder or different location using the wd.env file for your symbols icon?
    Check that the .dat file is in that location.
    If not,  check the Project settings dialog for the Schematic Icon menu path again.
    Thanks.
    Active Member
    01-22-2013 08:56 PM in reply to: lionSG
    I tried going to the project settings via project manager, but the command line read the it was an unknown command. Also, the wd.env file was not supported. It might be corrupt.
    Valued Contributor
    01-23-2013 10:44 PM in reply to: micruiz
    You may want to try to reset the settings back to default in ACE 2013.
    Try the steps in the link below:
    http://upandready.typepad.com/up_and_ready/2012/07/the-easiest-way-to-reset-autocad.html
    If not, try to uninstall the whole ACE, and delete away the user folders as well before you try to install again.
    C:\Users\Public\Documents\Autodesk\Acade 2013
    C:\Users\username\Documents\Acade 2013
    Active Member
    01-25-2013 05:32 PM in reply to: micruiz
    I uninstalled it, and then installed ACADE 2013. Everything seems to working out now.
