AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: error:no function definition : ACE_GETACT IVEPROJECT
- Highlight
- Email to a Friend
I tried that but it still not working. Now when I try to insert a wire or any other component the following message pops up:
"file not found: ace_jic_menu.dat...
...the file may be related to undefined environment paths in wd.env: WD-PROJ -- default path to project files"
- Highlight
- Email to a Friend
Are you pointing to a network share folder or different location using the wd.env file for your symbols icon?
Check that the .dat file is in that location.
If not, check the Project settings dialog for the Schematic Icon menu path again.
Thanks.
- Highlight
- Email to a Friend
I tried going to the project settings via project manager, but the command line read the it was an unknown command. Also, the wd.env file was not supported. It might be corrupt.
- Highlight
- Email to a Friend
You may want to try to reset the settings back to default in ACE 2013.
Try the steps in the link below:
http://upandready.typepad.com/up_and_ready/2012/07
If not, try to uninstall the whole ACE, and delete away the user folders as well before you try to install again.
C:\Users\Public\Documents\Autodesk\Acade 2013
C:\Users\username\Documents\Acade 2013
- Highlight
- Email to a Friend
I uninstalled it, and then installed ACADE 2013. Everything seems to working out now.
