• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    Accepted Solution
    error: malformed string on input
    381 Views, 2 Replies
    05-29-2012 05:45 AM
    There were a few posts on this but no concrete solution.  I'm getting this error now and basically all electrical functions are inoperable.  Is there anything I can try before doing a complete uninstall/reinstall?
    Please use plain text.
    *Expert Elite*
    Re: error: malformed string on input
    05-30-2012 08:53 PM in reply to: cmcleroy
    Be sure you have all updates installed for your version of Electrical.  If all else fails, try a repair install or a complete re-install.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    New Member
    06-05-2012 05:40 AM in reply to: cmcleroy
    I went to add/remove programs and did a repair.  This did not correct the problem.  I did find this post which solved the problem:
    "1. Close ACADE.
    2. Browse to your user folder:
    For example for ACE 2007, here is your user folder by default:
    C:\Documents and Settings\\Application Data\Autodesk\AutoCAD
    Electrical 2007\R17.0\enu\Support\User
    3. Rename or delete the LastProj.fil file under this folder.
    4. Restart ACADE"
    Thanks, Cliff
