• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    default catalog
    251 Views, 2 Replies
    09-13-2012 04:54 PM
    Good evening,
    I have recently installed Autocad Electrical 2013. Presently, i only have AB and ABB in the default_cab,mdb.
    I followed the instructions to add some other manufacturers, but the default catalog has not updated.
    I have windows 7 Family Premium.
    Do you have a solution to my problem ?
    Kind regards.
    Please use plain text.
    Active Contributor
    Re: default catalog
    10-15-2012 11:42 AM in reply to: ricardd1
    What you need to do is a complete search for the default catalog database on your pc and then after you find out where is resides make sure your AutoCAD is looking in that place. You may want to even open it in Microsoft Access to see if it is the correct one. If you have more then one it may be the wrong one and not be the one from the main installation directory. The installation directory looks as follows....
    C:\Documents and Settings\<username>\My Documents\Acade 2013\AeData\Catalogs
    Re : default catalog
    10-16-2012 01:06 PM in reply to: ricardd1
    If you use a french version, you need to uninstall Electrical 2013 and then reinstall it.
    Be careful and choose the manufacturers you want to use.
    Best regard,
