• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    david_vji
    database refresh
    139 Views, 2 Replies
    10-19-2011 04:09 AM
    when I changs somthing in my drawings autocad dos not notes changes until i have
    powerd autocad down an restarted
    Sample: I delead a terminal and the number is in use un til I reload autocad
    Best regards
    David
    Please use plain text.
    *Expert Elite*
    Re: database refresh
    10-19-2011 04:54 AM in reply to: david_vji
    It depends on how you deleted the component. If you used the Delete Component button then it should have updated the project database (assuming you are working in the active project). If you just erased the component using Autocad's erase function then the database is not updated. If you do this, you have to manually update the project database.
    Bob Hanrahan
    Ace User since 1998
    david_vji
    10-19-2011 05:00 AM in reply to: testsubject
    I am working in activ project and I used deleat compoment
    I have used AE for several years now and I have never  had
    this problem until know
    It is not just when I erase a compoment,
    when a chanse somting in a compoment, signal refrences
