• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Accepted Solution
    components NOT SHOWING TEXTVALUES
    203 Views, 2 Replies
    11-27-2012 11:33 AM
    Hello All,
    I am having an issue with inserting a component onto my schematic and the ratings not showing up.
    In the look-up catalog under the textvalue is the desired ratings i.e.FUSE (RATING1=5.0 A;DESC1=CLASS "CC").
    The ratings used to populate but have since stopped.
    Is there a setting for this??
    Both users here are having the same issue.
    As stated above it use to work fine.
    Any ideas??
    Dennis
    Please use plain text.
    Valued Contributor
    Re: components NOT SHOWING TEXTVALUES
    11-28-2012 05:04 AM in reply to: acade2012
    FYI for anyone else having this issue.
    I have found the cause of the issue.
    I recently modified the access data base to include the company part number.
    I added a column to the data base.
    once I went back and removed the column it started to insert the text values again.
    The column needs to be added to the end of the data base to work correctly
    *Expert Elite*
    11-28-2012 07:02 AM in reply to: acade2012
    Dennis,
    Good catch. In all my years of using ACE I never added a column to the database.
    Always learning something new...
    Bob Hanrahan
    Ace User since 1998
