• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    *Expert Elite*
    changing wire color project wide
    81 Views, 0 Replies
    09-24-2012 08:44 AM
    Has anyone found a good way to do this yet? I spent some time this morning searching and did not get anywhere.
    I could always go through and rename the layers but that does nothing to the Wire Labels that are already on the drawing. So far I use "Change/Convert Wire Type" for each wire type I want  to change and then select all wires using a filter to get the matching ones. As you can guess, this is a little time consuming to have to do each drawing one at a time. It would be nice if this API would work project wide...
    Bob Hanrahan
    Ace User since 1998
    Please use plain text.
