AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
changing text size not found in project wide utilities
2 REPLIES 2
streetglidewi
723 Views, 2 Replies
I want to be able to change text height and width for symbol attributes not part of the project wide utilities, such as CAT or FAMILY. Does anyone know how to write a script for this, or does it need to be a lisp file?
Thank you.
2 REPLIES 2
You can write a script that calls the AEATTSIZE command and executes it against each attribute.  You will also need to change the visibility status for the attributes, if you wish to see their value displayed on the drawing, which I assume you want,  You can call this script from Project-wide utilities so it can be executed against all drawings.
But bear in mind that the default size of these attributes is 0.01 and invisible is set to Yes.  If you change the size you will still need to reposition the attributes so they are not overlaying one another or the symbol graphics.
It the end you may be better off modifying the symbol blocks and using the Update Block utility to switch them out.  Note that you will have to do this once for each symbol but it will swap all occurrence of the symbol, project-wide.  After that it's smooth sailing because your library symbols will have the attribute height preset.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
I am having problems writing the script. I tried several different ways to write the script (which I have never done before), and had no luck. Any help?
”Boost
