• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Member
    ace_plc.mdb
    164 Views, 2 Replies
    08-09-2004 09:19 AM
    Where does AE 2005 store file ace_plc.mdb was using tutorial and when asked to use this file in the components, insert modules, insert PLC (parametric) i get AutoCAD Message File not found. I did a search on my local drives and i also searched the AutoCAD Electrical 2005 Disk and find no such file. Can anyone help. Thanks
    Please use plain text.
    *Nate Holt
    Re: ace_plc.mdb
    08-09-2004 06:22 PM in reply to: susanl
    It should be in "c:\documents and settings\{you}\Application Data\Autodesk\AutoCAD Electrical 2005\....\Support\AeData\Plc\" folder. "susanl" wrote in message news:14502718.1092068418184.JavaMail.jive@jiveforum1.autodesk.com... > Where does AE 2005 store file ace_plc.mdb was using tutorial and when asked to use this file in the components, insert modules, insert PLC (parametric) i get AutoCAD Message File not found. I did a search on my local drives and i also searched the AutoCAD Electrical 2005 Disk and find no such file. Can anyone help. Thanks
    Valued Contributor
    Re: ace_plc.mdb
    08-10-2004 11:32 AM in reply to: susanl
    When I first installed, I had an error where AE 2005 could not find this file, even though it said that it was looking for it in the directory where it was actually located. Since then, I have rebooted, and now the Insert PLC dialog comes up like it should. However, I do not know if rebooting had anything to do with it.
    - Jay
