• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    CAD-ICE
    Accepted Solution
    Zipping a project - Downwards compatibility
    154 Views, 5 Replies
    12-05-2012 03:57 AM
    Hi there,
    I have a college that needs a copy of my project which is made in ACADE2013. My college is working with ACADE2012 so my question is if I can in a simple manner zip my project such that he can work with it in ACADE2012.
    Any comments appreciated.
    Regards, Gary
    Please use plain text.
    *Expert Elite*
    Re: Zipping a project - Downwards compatibility
    12-05-2012 06:49 AM in reply to: CAD-ICE
    Gary,
    Couple of things...
    As long as you are not using the new sub-folder structure in the project it should be okay.
    Make sure that you SaveAs all the DWGs as 2010 or Older. With ACE 2013 there is a new file saveas format.
    That is what jumps to mind.
    Bob Hanrahan
    Ace User since 1998
    CAD-ICE
    12-05-2012 08:58 AM in reply to: testsubject
    Hi Bob and thank´s for the tip.
    So what you are saying is that I need to open all dwg´s in my project and save them as 2010 before I zip the project right?
    I was kind of hoping that there was a shortcut in ACADE that takes care of this automatically :smileyhappy:
    Thanks again, Regards, Gary
    Valued Contributor
    12-05-2012 01:20 PM in reply to: CAD-ICE
    Might want to check for a LISP routine that would open them and save as 2010.
    *Expert Elite*
    12-05-2012 02:24 PM in reply to: acade2012
    Just create an scr file with QSAVE in it and then run it from the project utilities for the whole project. Be sure to change your SaveAs Setting under AutoCAD Options to 2010 first.
    Bob Hanrahan
    Ace User since 1998
    *Expert Elite*
    12-06-2012 04:11 AM in reply to: testsubject
    I discovered an even easier way to do this but it requires installing DWG True View ( the latest version is available here http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=9078813 )
    Here is a blogpost detailing how to do this. Pretty clever!
    http://myacade.blogspot.in/2012_06_01_archive.html
    Bob Hanrahan
    Ace User since 1998
