• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Wire Number Text Size
    105 Views, 1 Replies
    02-07-2013 05:09 AM
    Can someone please advise how to set the wire number text size and wire gap size. I am using the auto wire insert and when wires cross I want a gap to be inserted, so the gap needs to open up when the text size is increased.
    Please use plain text.
    Distinguished Contributor
    s.wile
    Re: Wire Number Text Size
    02-07-2013 06:48 PM in reply to: STEVENAR
    Are you referring to the text in-line with the wire as in
    -----123-----
    The gap settings are in the drawing properties \ WireNumber Tab \ New Wire Placement \ In-Line \ Gap Setup... Button.
    The wire number height should be done at the block level. The block names for in-line wire number are: WD_WNH1 and WD_WNV1
    If your changing them, you should change the rest as well.
    Above wire: WD_WNH and WD_WNV
    Below wire: WD_WNH2 and WD_WNV2
    Or do you mean when another wire happens to run through another wires wire number?
    Stan Wile
    http://myacade.blogspot.com/
    IMAGINiT Technologies
