AutoCAD Electrical
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Wire Number Insertion Problem !!
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
67 Views, 2 Replies
03-29-2004 02:00 PM
Hello Everyone,
I just started using Autocad Electrical for our product design. I have a problem with wire number insertion.
I created my diagram ( by cutting and paste from a previous backup drawing) and inseted wire numbers using the tool provided. The size of wiere number inserted is 5'' by 2'' and and i am unable to reduce the size. However, when i insert wire number in my backup drawing it displays them correctly. I can't use this back up drawign as its incomplete.
Any help will be highly appreciated.
Nouman Saeed Raja
Eletrical Engg.
Mid-American Elevator Co.
Nouman Saeed Raja
Eletrical Engg.
Re: Wire Number Insertion Problem !!
Options
- Highlight
- Email to a Friend
03-30-2004 07:39 AM in reply to:
Nouman
check to make sure the units of measure are the same on your new drawing as they were on your old drawing. also check thing like dimscale. I would also check the text style dialog, sometimes that has a text size typed in that will override others.
*Nate Holt \(Autodesk\)
Options
- Highlight
- Email to a Friend
03-30-2004 09:36 AM in reply to:
Nouman
Nouman,
It could be a "Symbol LIB" issue. Your current project probably has the
"IEC2" symbol library set up to be the default. It is scaled to units
appropriate for millimeter insertion (2 unit text size). On your backup
drawing you probably already have an existing wire number block/insert that
comes from the "JIC1" or "JIC125" library (English units, 0.1 text size or
so) on your drawing so it's not going out and getting the "2 unit" version.
As a test, select the "Symbol LIB" button in bottom left-hand corner of the
"Project" dialog. Check the "schematic library" search path.
Nate.
