• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    New Member
    Wire List
    77 Views, 1 Replies
    01-10-2013 10:00 AM
    I had some schematic made using AUTOCAD, my goal is to export the wire list including the information of the wire name, from/to, wire guage and the length. I believe AUTOCAD Electrical should be the right software for this kind of reporting. Could anyone give me some guideline? Thanks
    Please use plain text.
    Valued Contributor
    Re: Wire List
    01-10-2013 05:45 PM in reply to: emailbilly
    I believe you need to convert your blocks into electrical components and lines into wires first.
    you can make use of the Conversion Tools tab to do that.
    Then you can do a to/From report from the Report tab.
    If you need more info, you can look into the Tutorial in the help files.
    Hope this helps.
