AutoCAD Electrical
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
WIRE NUM ORIENTATIO N
Options
- Highlight
- Email to a Friend
61 Views, 3 Replies
04-19-2004 11:46 AM
Can I specify that a wire # goes in on a vertical wire oriented along the wire as a default, rather than oriented horizontally? Do I just edit the vertical block?
Lynne
Lynne
Re: WIRE NUM ORIENTATIO N
Options
- Highlight
- Email to a Friend
04-29-2004 07:10 AM in reply to:
Lint
THAT WOULD BE THE EASIEST METHOD
*Jared Bunch \(Autodesk, Inc\)
Options
- Highlight
- Email to a Friend
05-06-2004 02:41 PM in reply to:
Lint
Lint
I cannot think of anything you could do to force all of the wire number
to be placed on a vertical wire. Is this a common practice that you have?
The best thing I can think of that you could do would be to just use the
MOVE WIRE NUMBER command to move those that get placed on horizontal wires
to a vertical wire. Please let me know if this is something that you would
like added as a change request. I would assume that you would like to see
an additional option allowing you to specify placing the wire numbers only
on the vertical or only on the horizontal wires where possible? Am I
correct?
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"Lint" wrote in message
news:16549525.1082400455048.JavaMail.jive@jiveforu m2.autodesk.com...
> Hi,
vertical block?
> Lynne
Options
- Highlight
- Email to a Friend
05-07-2004 06:08 AM in reply to:
Lint
Hi Jared,
I like to put the wire numbers at the top and bottom of the vertical wires for the 3ph and 24v for each ladder.
I solved the problem pretty easily just by editing to vertical wire block.
