• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    WIRE FROM TO REPORT ADD COMPONENT DESC1 THROUGH 3
    146 Views, 2 Replies
    12-07-2012 09:10 AM
    IS THERE A WAY TO INCLUDE THE COMPONENT DESCRIPTION TO THE WIRE FROM TO REPORT?
    I AM WANTING TO INCLUDE THE DESCRIPTION BECAUSE I NEED A WAY TO DISTINGUSH BETWEEN MULTIPLES OF THE SAME COMPONENTS WHEN THEY ARE IN DIFFERENT LOCATIONS. EX. I HAVE SET THE LOCATION CODE FOR 20 LIGHTS TO "FIELD." EACH LIGHT HAS A UNIQUE NAME THAT DESCRIBES ITS LOCATION "MOTOTR XYZ LIGHT" I DO NOT WANT TO GIVE EACH OF THEM DIFFERNT LOCATION CODES BECAUSE THEN I WOULD HAVE TO CREATE A TAG TO PUT ON THE JUNCTION BOX THAT RELATES TO THE COMPONENT.
    IF THERE IS A BETTER WAY OF DOING THIS PLEASE LET ME KNOW. I REALLY DONT WANT TO HAVE TO GENERATE THE TAGS AND TAG NAMES
    I HAVE SAW THE LISP ROUTINE IN "WIREFROM/TO REPORT" DATED 07-15-2004
    I HAVE NOT TRIED TO GET THIS TO WORK SINCE IT SEEMS OUTDATED
    I AM RUNNING AE 2013
    ALSO,
    HOW DO I CHANGE THE NAME OF THE USER 1 FIELD IN THE DEFAULT_CAT?
    THANK YOU
    Please use plain text.
    Re : WIRE FROM TO REPORT ADD COMPONENT DESC1 THROUGH 3
    12-17-2012 06:18 AM in reply to: Vulcan1970
    For your second question, use ACCESS.
    Open the default_cat.mdb and rename the fiels USER1 in every family table.
    Best regards
    Active Contributor
    12-17-2012 06:25 AM in reply to: bpasqualini
    Thank you, changing the name in each table worked
