• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    oveimariemamn
    Accepted Solution
    WD_M.dwg
    213 Views, 1 Replies
    12-09-2011 05:02 AM
    I get the error: AC electrical can't find the file WD_M.dwg when trying to put a component from IEC list.What is wrong?
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    Re: WD_M.dwg
    12-10-2011 02:57 AM in reply to: oveimariemamn
    Hi.
    Check the symbol library paths for the active project. Seems like they are a little bit off. The WD_M block is in one of these folders.
    THL
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
