• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    *Nate Holt \(Autodesk\)
    Vertical Wire Numbers - how to
    153 Views, 2 Replies
    03-08-2005 03:08 PM
    This comes up from time to time. You want wire numbers for vertical wires to come in automatically rotated 90 degrees so that the wire number lays along the wire. To do: 1. Determine the schematic symbol library in use and open drawing "wd_wnv.dwg" in AutoCAD. 2. Rotate the WIRENO attribute 90 degrees (you can use the AcadE "rotate wire number" cmd if you'd like) 3. Save 4. Open drawing "wd_wcv.dwg". Repeat steps 2 and 3. That's it. Wire numbers for new drawings will come in auto-rotated.
    Please use plain text.
    *Robert Stein
    Re: Vertical Wire Numbers - how to
    03-09-2005 07:15 PM in reply to: *Nate Holt \(Autodesk\)
    Great tip Nate. Robert Stein INCAT rstein@incat.com www.incat.com "Nate Holt (Autodesk)" wrote in message news:422e3068_3@newsprd01... > This comes up from time to time. You want wire numbers for vertical wires to > come in automatically rotated 90 degrees so that the wire number lays along > the wire. To do: > > 1. Determine the schematic symbol library in use and open drawing > "wd_wnv.dwg" in AutoCAD. > 2. Rotate the WIRENO attribute 90 degrees (you can use the AcadE "rotate > wire number" cmd if you'd like) > 3. Save > 4. Open drawing "wd_wcv.dwg". Repeat steps 2 and 3. > > That's it. Wire numbers for new drawings will come in auto-rotated. > >
    Active Member
    08-29-2011 11:39 AM in reply to: *Robert Stein
    It would be nice to have a Rotate Wire Number (Rotate Attribute) command located next to the flip and toggle (in-line) icons in the Ribbon.
