AutoCAD Electrical
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
[VBA] Writing a data from excel to autocad without openning autocad manuelly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have trouble in my task. I am trying to write the data of an excel cell into autocad ( string data ).
The following code is almost right but it doesn't write the text in autocad.
(open autocad and add drawing only)
If anyone has an idea on the problem.
Regards
Nicolas
Code VBA:
Public ThisDrawing As AcadObject
Sub test()
Dim xAP As Excel.Application
Dim xWB As Excel.Workbook
Dim xWS As Excel.Worksheet
Dim Height As Double
Dim P(0 To 2) As Double
Dim TxtObj As AcadText
Dim TxtStr As String
Dim AcadObj As AcadApplication
Dim AcadDoc As AcadDocument
Set xAP = Excel.Application
Set xWB = xAP.Workbooks.Open("C:\Path\Name.xls")
Set xWS = xWB.Worksheets("Sheet1")
MsgBox "Excel says: """ & Cells(1, 1) & """"
On Error Resume Next
Set AcadObj = GetObject(, "AutoCAD.Application")
If Err.Number <> 0 Then
Set AcadObj = CreateObject("AutoCAD.Application")
NombreDessinAutocad = 2
End If
AcadObj.Visible = True
MsgBox "Step_1"
Set AcadDoc = AcadObj.Application.Documents.Add
MsgBox AcadObj.name & " version " & AcadObj.Version & _
" is running."
Set AcadUtil = AcadDoc.Utility
Set AcadEspaceObj = AcadDoc.ModelSpace
MsgBox "Step_2"
Height = 10
P(0) = 1: P(1) = 1: P(2) = 0
TxtStr = Cells(1, 1)
MsgBox TxtStr
Set TxtObj = AcadObj.ModelSpace.AddText(TxtStr, P, Height) <------doesn't work
Set TxtObj = ThisDrawing.ModelSpace.AddText(TxtStr, P, Height) <------doesn't work
MsgBox "End"
End Sub
Re: [VBA] Writing a data from excel to autocad without openning autocad manuelly
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This was a little mystake, her is the solution:
Sub test()
End If
MsgBox "Step_1"
" is running."
MsgBox "Step_2"
Height = 10
MsgBox TxtStr
'Set TxtObj = AcadObj.ModelSpace.AddText(TxtStr, P, Height) <------doesn't work
'Set TxtObj = ThisDrawing.ModelSpace.AddText(TxtStr, P, Height) <------doesn't work
Set TxtObj = AcadEspaceObj.AddText(TxtStr, P, Height) <-------- Work !
MsgBox "End"
End Sub
