• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    [VBA] Create a folder and a project
    135 Views, 3 Replies
    12-11-2012 12:15 AM
    I found how to open autocad and how add drawing by looking on forums and the help section au AtucadElectrical but there is a thing that i can't find:
    How to create a folder, a projet and add (new drawing to that folder)
    Regards
    Nicolas
    This is the beginning of the code:
    Sub Initialise()
        Dim NewDrawing1 As AcadDocument
        Dim Newdrawing2 As AcadDocument
        On Error Resume Next
            Set AcadObj = GetObject(, "AutoCAD.Application")
            If Err.Number <> 0 Then
                Set AcadObj = CreateObject("AutoCAD.Application")
                NombreDessinAutocad = 2
            End If
            AcadObj.Visible = True
            Set AcadDoc = AcadObj.ActiveDocument
            Set AcadUtil = AcadDoc.Utility
            Set AcadEspaceObj = AcadDoc.ModelSpace
            Set NewDrawing1 = AutoCAD.Application.Documents.Add("")
            Set Newdrawing2 = AutoCAD.Application.Documents.Add("")
            Dim drawing As AcadDocument
            For Each drawing In AutoCAD.Application.Documents
                drawing.Activate
                MsgBox "Drawing " & drawing.Name & " is active."
            Next drawing
        Excel.Application.Visible = True
    End Sub
    Please use plain text.
    johnq
    Re: [VBA] Create a folder and a project
    12-12-2012 01:56 PM in reply to: Nicolas.L
    Hi Nicolas
    Your question has a lot to it.
    While I could show you, it is too long winded to answer here.  I know that is not what you need to know.
    I do not sell training so when I suggest you should get some training then it it true.
    Now to help with limited 18 months experience:
    I could not create a project for scratch.   I needed to open a project from the built in Tutorials in ACE.  Open a drawing from that project.
    That project needed to be Active.   It is bold high lighted.
    Then I could go through the process of creating a project.
    If I had a choice I would have a seperate Letter drive for ACE even if you only had one physical drive.
    Also go to www.ecadconsultant .com  There is some good info but I must be thick as some of it I found criptic but eventually I got the message.
    Cheers  John QUigley
    johnq
    12-12-2012 02:44 PM in reply to: johnq
    Hi Nicolas
    I should have tried to find out what VBA was before I tried to help.  I have just made a fool of my self as I think you are using Vault etc.
    Forgive me for I know what what i do.
    All the best forthe new year.
    Cheers  jq
    12-12-2012 10:43 PM in reply to: johnq
    Hi John,
    First of all thanks to take time on my problem.
    I use VBA, maybe it's also call VB, anyway it is a .NET language. I stopped using this language and I goes on a maybe more structural oriented programming language which is C#.
    I don't really understood all the things of your answer but I understood that it is not as easy as I thought.
    Thanks for your answer,
    Have an Happy new year
    Nicolas
