• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    [VBA] Adding a drawing to a project folder
    209 Views, 2 Replies
    12-19-2012 02:54 AM
    Is someone know the command to add the activate drawing to the project ?
    My problem is that, I am generating various drawing and I would like to add them to a project, If someone know how to do that, It can help me.
    ei:
    Sub test2()
    Dim AcadObj As AcadApplication
    Dim AcadDoc As AcadDocument
    On Error Resume Next
    Set AcadObj = GetObject(, "AutoCAD.Application")
    If Err.Number <> 0 Then
        Set AcadObj = CreateObject("AutoCAD.Application")
        NombreDessinAutocad = 2
    AcadObj.Visible = True
    Set AcadDoc = AcadObj.Application.Documents.Add("C:\PATH\Cartouche_V1.0.dwt")
    Set AcadUtil = AcadDoc.Utility
    Set AcadEspaceObj = AcadDoc.ModelSpace
    Set blockRefObj = AcadEspaceObj.InsertBlock(P, "C:\PATH\Mop_V1.1.dwg", 1#, 1#, 1#, 0)
    document to the project
    Set ...... **Looking for the command to add my drawing to the project**
    End Sub
    Regards
    Nico
    Please use plain text.
    Valued Contributor
    Re: [VBA] Adding a drawing to a project folder
    12-20-2012 09:53 AM in reply to: Nicolas.L
    I could not find any type of command to add a drawing to the project like you are looking for however you could just write some code to add the information to the project.wdp file. Its just a text file so its shouldn't be to difficult. You could also add some other info like Descriptions and Section or Subsection. Its in this format
    =section
    ==subsection
    ===description 1
    ===description 2
    ===description 3
    test.dwg
    I use notepad to edit the ".wdp" file when I need to add lots of drawings with section and description information quickly.
    You need to close the project before doing this and I always make backups of the file before changing things just in case!
    Distinguished Mentor
    rhesusminus
    01-14-2013 10:50 PM in reply to: Nicolas.L
    Hi Nico.
    You should search for the VLAX-class that makes it easy for VBA to communicate with LISP, as the AcadE API is solely based on AutoLISP.
    Then you should have a look in the help file.
    Look for c:ace_add_dwg_to_project
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
