• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Updating drawing name value (the %D value)
    334 Views, 5 Replies
    02-02-2009 02:59 PM
    I've been a long time user of ACE 08 but have never set-up the 'dwgnam" value in the title block. I recently figure that in order to make off-page wire referencing work, I would need to set the "dwgnam" attribute in the title block and have done so. My question is is the "dwgnam" suppose to auto update upon doing a project "title block update" (similar to the "sheet" value)? It seems to work if I manually type in the drawing name from drawing properties. Please let me know how this value works and how it gets updated.
    Please use plain text.
    *Brad Coleman
    Re: Updating drawing name value (the %D value)
    02-02-2009 09:02 PM in reply to: gvang
    To get the dwgnam to update, the data has to
    present in the 'Drawing' box in the sheet values section of the drawing
    settings. When you do a 'Title Block Update', you need to select the check box
    next to 'Drawing (%D value)'. This will let the function know to update this
    value.
    I assume you have the drawing attribute mapped to
    drawing setting in your title block setup...
    Regards Brad
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">I've
    updated.
    Active Contributor
    02-03-2009 08:44 AM in reply to: gvang
    Brad,
    When you say...data has to be present in the "drawing" box in the sheet value sections of the drawing setting, are you saying that this data has to be manually inputted for each drawing from that location? My question is does the drawing value (%D value) auto update...similar to that of the sheet value (%S value) when doing a "title block update"? Yes, the check-box is checked and the attribute is mapped correctly (see below for "wd_tb" setting). let me know your thoughts.
    ( OWNER = LINE1;JOBTITLE = LINE2;CONTENT = LINE3;ENG = LINE4;DFT = LINE5;STATUS = LINE6;DATE = LINE7;JOB = LINE8;SHT = SHEET;MAX = SHEETMAX;FILE = FILENAME;SECT = DWGSEC;DESC1 = DD1;DESC2 = DD2;DESC3 = DD3;R1 = LINE18;R1DATE = LINE19;R1BY = LINE20;R1DESC = LINE21;R2 = LINE22;R2DATE = LINE23;R2BY = LINE24;R2DESC = LINE25;R3 = LINE26;R3DATE = LINE27;R3BY = LINE28;R3DESC = LINE29;R4 = LINE30;R4DATE = LINE31;R4BY = LINE32;R4DESC = LINE33;DSTAMP = PLOTDATE;TSTAMP = PLOTTIME;{color:#ff0000}DWG = DWGNAM ){color}
    *Brad Coleman
    02-03-2009 03:31 PM in reply to: gvang
    OK...
    No the drawing value does not auto update. It
    actually represents the drawing number/name. It has to be set once in that
    position to for each dwg. This makes it possible to have dwgs that use letters
    in the dwg number with no problems.
    Regards Brad
    Brad,
    When
    your thoughts.
    = DWGNAM ){color}
    Active Member
    tonymynd
    11-01-2012 03:42 PM in reply to: gvang
    Hello Gvang!
    I tryed many ways and still can't make AutoCAD Electrical to automatically update the Drawing value, this way my file name would be automatically inserted in all my references. WHICH IS GREAT
    Why? BECAUSE I DON'T have to manually input the values in the Drawin text box on each drawing properties Dialog Box and the Magic here is tha I CAN USE %D in all my xrefs !
    Please see atachment, I'm hoping you can see my problem
    Distinguished Mentor
    11-01-2012 07:46 PM in reply to: tonymynd
    Generally, once you set the dwg number, it does not change. The sheet number can change depending on various things which is why this will update automatically when the correct command is used.
    Whenever I start a new dwg, this is one of the setting I fill in, along with all the other settings in this dialog.
    The company I work for uses a three part dwg number so I have three attribute set up in the title block.
    The first part is the Project (or job) number (6 characters), followed by the dwg number (2 characters), finally followed by the sheet number (also 2 characters).
    The project number is set in the Project descriptions and doesn't change from dwg to dwg.
    However, both the dwg number and the sheet number are set in the drawing settings. The dwg number also will not change but the sheet number will as it is moved around in the sheet set for that particular dwg.
    In your situatuation, you may want to have the attribute you mapped for the dwg number to actually be mapped to the filename. This will then automatically update the number you see on the dwg when you run the title block update... You just need to make sure the checkbox is selected for it.
    Only problem is this will not affect your sheet references. You may have to try putting the %F in your cross reference setup. However you will have to do a full project cross reference update each time your filename updates.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
