• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Accepted Solution
    Undo command disabled?
    482 Views, 8 Replies
    12-05-2012 09:24 AM
    Why is my UNDO command disabled?
    Jim
    Please use plain text.
    Member
    Re: Undo command disabled?
    12-06-2012 04:40 AM in reply to: jdonaldson3
    REINSTALL YOUR CAD THATS THE ONLY WAY TO GET YOU UNDO TO WORK RIGHT. I TRIED EVERYTHING AS WELL BUT NOTHING WILL RESTORE IT BUT AN REINSTALL.
    Distinguished Mentor
    rhesusminus
    12-06-2012 04:43 AM in reply to: jdonaldson3
    Type UNDO at the command-line and select option "One".
    Now, the U command undoes one command at a time.
    If this doesn't work, type UNDOCTL at the command-line, and tell us what value this is set to...
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
    Valued Contributor
    12-07-2012 06:03 AM in reply to: rhesusminus
    That appears to work. But only after I typed UNDO a second time. The first time I typed UNDO and entered 1. Autocrat replied that I needed to enter a number from 1 to 3####. You know a typical Autocrat WTF answer.
    Second time around and it worked.
    Thanks.
    Jim
    rhesusminus
    12-07-2012 06:13 AM in reply to: jdonaldson3
    Hmm..
    How about
    UNDO
    CONTROL
    ALL
    What does UNDOCTL give you?
    THL
    Valued Contributor
    12-07-2012 09:50 AM in reply to: rhesusminus
    UNDOCTL = 48 (read only)
    rhesusminus
    12-07-2012 04:52 PM in reply to: jdonaldson3
    And if you type
    UNDO
    CONTROL
    ALL
    what's the value for UNDOCTL then?
    THL
    Valued Contributor
    12-10-2012 06:49 AM in reply to: rhesusminus
    UNDOCTL = 53 (read only)
    Valued Contributor
    12-10-2012 07:06 AM in reply to: jdonaldson3
    OK another reason to hate Autodesk. Appearently this has been happening since 2008 Electrical
    http://discussion.autodesk.com/forums/thread.jspa?threadID=652307
    I am so glad that I get to use software that's had the same bug for over 5 years that dirrectly effects using the software. Thank you  Autodesk.
