• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Accepted Solution
    To adjust the line type scale.
    206 Views, 4 Replies
    12-11-2012 12:19 AM
    To adjust the line type scale until dashed line types appear as fine or coarse as desire,Type
    LSCALE
    OR
    LTSCALE.
    PLZ HELP
    Regards
    ersidhu.
    Please use plain text.
    johnq
    Re: To adjust the line type scale.
    12-12-2012 01:31 PM in reply to: ersidhu
    Hi Ersidhu
    I will try to help, I have been using ACE for about 18 months.
    Your question seems ot indicate that you understand AutoCAD and use commands where I have used mostly used Icons.
    In AutoCAD Electrical all commands are prefixed with AE.
    I change line types and width etc in the layer tables.  It is the only way I know.  There may be a more elegant technique but I am not that educated.
    Hope I am not telling you what you already know.
    Cheers  john Quigley
    *Expert Elite*
    12-13-2012 01:11 AM in reply to: ersidhu
    The LTSCALE command can be typed at the command line as you mentioned.  The factor you set determines how coarse or fine the dashes appear.  This is a drawing-wide setting.  Once you are happy with the setting, you should set your template up the same way so all future drawings are preset with your desired line type scale.
    Hint: This setting is most helpful to make sure dashed link lines between contacts and dash dot lines for location boxes appear clearly.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    12-13-2012 01:56 AM in reply to: dougmcalexander
    Thanks Sir,
    You are great.
    Thanks & Regards
    ersidhu.
    *Expert Elite*
    12-13-2012 01:59 AM in reply to: ersidhu
    You are welcome.  Glad to help.
    Doug McAlexander
