• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Justin2012
    Re: Title block and symbol buider
    06-25-2012 05:53 AM in reply to: testsubject
    Please refer to the attachments and let me know what I can be doing wrong here. As you know this is preventing the project title block update from working.
    Again help will be gratefully appreciated.
    Please use plain text.
    Justin2012
    06-25-2012 06:01 AM in reply to: Justin2012
    I forgot to add the WDL file just incase you might need it. Please let me know what might be the problem.
    Thanks.
    *Expert Elite*
    06-25-2012 07:25 AM in reply to: Justin2012
    Thanks for adding the WDL. It was helpful.
    I looked at the titleblock. The reason DRAFTER and TITLE not showing up is because these attributes do not exist on the drawing.
    I can guess that you want DRAWN=Line6 not DRAFTER. As For TITLE, it is set for the Drawing Description Line 1 (TITLE=DD1) but you do not have any attribute on the drawing for this information. If you do not plan on including it on the titleblock, you can remove it from the WD_TB attribute.
    If you correct these things, the titleblock should update. Also keep in mind that if nothing has changed or the fields are blank, you will get the "No Change" response for all the titems in the WD_TB.
    I hope this helps.
    Bob Hanrahan
    Ace User since 1998
    *Expert Elite*
    06-25-2012 07:36 AM in reply to: Justin2012
    I think I saw something in an earlier post about a .WDT file being used. This file is not necessary if using the WD_TB method. The software looks first for a WD_TB mapping attribute and, if not found, it then looks for a .WDT mapping file.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    Justin2012
    06-25-2012 10:41 AM in reply to: dougmcalexander
    I am sorry but it is still not working. Please refer to the attachment.
    Thanks.
    *Expert Elite*
    06-25-2012 11:32 AM in reply to: Justin2012
    Justin,
    I went through and fixed the titleblock and created a titleblock template for use to use to create new drawings.
    The problem was that there was a lot of "garbage" existing in the drawing; hidden wire numbers, blocks not needed, layers not needed, and the big killer, an extra WD_TB that was hidden which was interupting the WD_TB that you were trying to modify.
    If you need to make any changes, open the .dwt and edit teh tileblock using "Edit Block" from within the Block Editor Window, yo uwill be able to modify the attributes for the titleblock. You can even run "Project\Title Block Setup" from within it.
    Just Close and QSave when finished
    I hope this helps.
    {note to moderators: Come ON!! .dwt's are not allowed as an attachment???}
    Bob Hanrahan
    Ace User since 1998
    Justin2012
    06-25-2012 12:16 PM in reply to: testsubject
    Bob,
    Thanks! The drawing is coming up as blank.
    For my understanding, how do you went about fixing the drawing and most importantly finding the hidden WD_TB? It will be good to know so as to avoid this from happening again.
    Thanks again.
    *Expert Elite*
    06-25-2012 12:40 PM in reply to: Justin2012
    When I used the titleblock, I saw that there were two WD_TB calls.
    I inspected the drawing and discovered that there were several layers in the titleblock (which are not needed) and 2 of them were turned off. After turning them back on, I saw about 50 wire numbers and an extra WD_TB. This was what blocking the Title Block Update.
    I purged all the extra items from the Title Block and resaved it. I aslo removed the references to the two attributes that did not exist. That cleared up the problem and it updated just fine.
    Bob Hanrahan
    Ace User since 1998
    Justin2012
    06-25-2012 02:07 PM in reply to: testsubject
    Thanks ! How did you check and discover I have two title block?
    The template that you created is not openning. Please check and resend it.
    Thanks.
    *Expert Elite*
    06-25-2012 03:01 PM in reply to: Justin2012
    What version of Autocad Electrical are you using??
    Bob Hanrahan
    Ace User since 1998
