I made some assumptions as to your experience level. Sorry about that.
1. Add all the components you want to add the new attribute to to a new project and make it active.
Should I add only the component tag names? Should I use colon to separate them
I am taking advantage of ACE's ability to run batch functions.
What I meant here was create a brand new project and add all the component drawings (i.e., HCR1, HFU1, etc) that you want to modify to the project.
2. Add the attribute to one of you component drawings and save it (you will skip this one during the batch process).
I used the add attribute command to add a new attribute to a component.
That only works to add an attribute to a component that exists in a schematic. If you want to affect all copies of this component (for now and forever), you need to open the original .dwg and add an attribute using ATT and fill in all the info. That is what I have been suggesting.
3. Copy the new attribute to the clipboard using Copy With Base Point (CTRL+SHIFT+C) and selecting 0,0 as your basepoint.
How do you go ahead copying this attribute?
You copy the attribute just like you would copy any object using Autocad. Select an object (like your new attribute) and then I like to use the Right Mouse Click/Clipboard/Copy With Base Point (CTRL+SHIFT+C). You are then asked for a basepoint and I would enter 0,0.
Might I suggest that you take a class in how to use Autocad Electrical? There is a lot of stuff going on that can be difficult to "just pick up on the fly".
I hope this gets you going in the right direction.
Bob Hanrahan
Ace User since 1998
Autodesk Expert Elite Alumni
If this answered your question, please click on "Accept Solution"
