• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Accepted Solution
    Text style for wire color/gauge
    195 Views, 5 Replies
    02-04-2013 10:53 AM
    I've been using Electrical 2010 for a little while now, but for the life of me I cannot remember how to change the text syle of the wire color/gauge leader. It comes in on the 'standard' layer, but I want to use 'simplex'. How do I change it? I can't seem to find any information for this particular issue.
    Thanks in advance. :smileyhappy:
    Julie
    Please use plain text.
    Active Contributor
    btackes
    Re: Text style for wire color/gauge
    02-04-2013 01:43 PM in reply to: junkinjam
    "The label text size follows the current AutoCAD DIMTXT setting and the arrow size defaults to the current AutoCAD DIMASZ setting."  Font style is DIMSTLYE
    Valued Contributor
    02-04-2013 01:51 PM in reply to: junkinjam
    Yes, I did read that. But where would I find the DIMTXT setting? If I enter 'dimtxt' on the command line it only gives me the option of changing the text size, not the font.
    Thanks.
    Active Contributor
    btackes
    02-04-2013 02:01 PM in reply to: junkinjam
    Font style is DIMSTYLE then click modify
    Distinguished Mentor
    02-04-2013 02:03 PM in reply to: junkinjam
    Go to the Format menu and select the Dimension Style.
    Now select the Text tab and you can change the font, style, size and a few other items. Other tabs allow you to change other settings to do with dimensioning.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Valued Contributor
    02-06-2013 04:46 PM in reply to: Icemanau
    Thanks! That was what I needed :smileyhappy:
