• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Accepted Solution
    Terminal Strip Editor - Wire Numbers
    229 Views, 2 Replies
    02-25-2013 07:19 AM
    I am using terminal trip editor to create my terminal block arrangements from the terminals placed in my schematics drawings. The terminal block arrangement drawings should be auto-generated and require no manual intervention. However this is rarely the case. I normally need to tidy up the wire numbers placed on either side of the terminals. For example on my schematics I have W10 cable which has 3 wires W10-1,W10-2 & W10-3 going into one side of the terminals and X10 cable again with 3 wires X10-1, X10-2 & X10-3 coming out the other side of the terminals. When I generate the terminal strips I would like to see X10-1, X10-2 & X10-3 on one side of the terminals and W10-1, W10-2 & W10-3 on the other side. However the wire numbers are mixed on either side.  I also find that some wire numbers are not picked up from the schematic drawings and I need to populate that information myself on the terminal block arrangement drawings. Can some please advise on how to correct this.
    Thanks in advance.
    Please use plain text.
    Active Contributor
    JMARSHALL1249
    Re: Terminal Strip Editor - Wire Numbers
    02-25-2013 08:59 AM in reply to: STEVENAR
    You need to put Internal & External markers onto the terminals, then all Extermal will be on one side, and Internal on the other.
    Go to Wires / Wire Misc / Terminal Connection Direction
    This shows options:-
    Show terminal directions
    Mark Internal
    Mark External
    Erase Markers.
    All internal markers are indicated by a Red Arrow, external are indicated by a Green Arrow, when you Show terminal directions.
    With regard to wire numbers not installing correctly, sometimes a Project Rebuild is necessary.
    Valued Contributor
    02-26-2013 12:59 AM in reply to: JMARSHALL1249
    Thanks for your help.
