• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    JMARSHALL1249
    TITLE_BLOCK CHANGED RANDOMLY SINCE 2013
    196 Views, 8 Replies
    08-13-2012 07:18 AM
    Yet again, I have had a drawing within a project have its TITLE_BLOCK changed randomly???
    Some, but not all border lines & company sysmbol are missing???
    Anyone got any ideas.  I have checked the original layers and they are all turned on.
    Please use plain text.
    Re: TITLE_BLOCK CHANGED RANDOMLY SINCE 2013
    08-13-2012 12:13 PM in reply to: JMARSHALL1249
    Hi
    Can you post a copy of your dwt?
    Arq. Ernesto Fraga
    Montevideo - Uruguay
    Active Contributor
    JMARSHALL1249
    08-14-2012 12:47 AM in reply to: JMARSHALL1249
    Unfortunately, I no longer have a copy with the deleted lines/logo etc.  When it happens again, I will post it.
    Basically, when it happens, I do a block update, and use a block stored on my desktop to correct the TITLE_BLOCK that has been changed within the drawing itself.  I have attached a copy of the original TITLE_BLOCK in the meantime.
    Active Contributor
    JMARSHALL1249
    08-14-2012 03:28 AM in reply to: JMARSHALL1249
    I have found another drawing with its TITLE_BLOCK that has been changed.  I have attached the DWG file of it.
    John.
    Active Contributor
    JMARSHALL1249
    08-15-2012 12:47 AM in reply to: JMARSHALL1249
    I have recently noticed that there are blocks stored within some of my drawings called TITLE_BLOCK0, TITLE_BLOCK1.  Does anyone know how these aget generated, and if there is any link to my drawing border errors?
    *Expert Elite*
    08-15-2012 12:05 PM in reply to: JMARSHALL1249
    I can answer the extra blocks question. Those are generated everytime you use Swap/Update block to update a block. ACE makes a copy of the original block appending a number to it and saves the updated block with the old block name. It is safe to purge them.
    Bob Hanrahan
    Ace User since 1998
    *Expert Elite*
    08-16-2012 06:15 AM in reply to: testsubject
    John,
    I took a look at the drawing and cannot see anything that jumped out at me. I used the Title Block.dwg that you provided and had no trouble updating the block to correct the issue. This one is strange. Do you think that there is a copy of Title Block.dwg somewhere else in your system that matches what you are seeing? I would check all your folders to see if you can find one. There must be a copy somewhere with this partial titleblock.
    Are you working with older prints that my have had a project wide Swap/Update applied with this corrupted titleblock?
    Disgruntled ex employee??  ;-)
    This is a tough one.
    Sorry I could not help more.
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    JMARSHALL1249
    08-16-2012 08:06 AM in reply to: testsubject
    We only have two AE users, and no ex-users have left the company.  We have only had the problem since we updated to AE2013.  The change to the border is random.  Yesterday, I had a sheet that had only the company logo missing, but all attributes and other lines etc were intact.
    It first occured with our other AE user, who is quite new to the company, and I assumed it was a user error somehow.  Now that it has happened to me, I said " I wouldn't have believed it was possible to alter the Title_block, until I saw it with my own eyes.  I am at a loss to understand how it can happen.  We have made changes to our drawing template recently, but surely this would not produce, seemingly random changes, to a random sheet or sheets within a project.
    When it occurs I do a project wide block update of the Title_Block.  For some reason, I then have to purge out all Title_block0 blocks as they stop the project manager from printing off the drawings.  At least I have a solution, but it is annoying that I cannot find the cause. :smileysad:
    Active Member
    MikeAldridge1953
    08-18-2012 04:27 AM in reply to: JMARSHALL1249
    I too have experienced this strange behaviour, my symptoms were identical - company logo and random lines missing from title block problems printing and updating. Problem would manifest itself on random sheets.
    Is your company logo an embedded Jpeg? this seemed to be the root of my problem.
    I solved my problem by creating a new title block based on one of the standard templates, creating the logo using plain text rather than a Jpeg. Since then i have not had the problem.
    Regards
    Ian
