AutoCAD Electrical
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
TEXT REPLACEMEN T SCRIPT (RE)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
73 Views, 4 Replies
01-03-2007 12:09 PM
I'm re-posting this since I didn't get any answer the first time.
I wrote a script to change multiple attributes in my title block. All but one of the attributes changed flawlessly. I used the same format to change the other one, but for some reason it doesn't work. It says:
Enter attribute value specification <*>:
0 attributes selected.*Invalid*
Here is my script. Everything works until it prompts "Enter attribute value specification <*>:" when I'm changing the attribute "REV1ECN#"
-ATTEDIT
N
N
BORDERPSC-D
REV1
1
-AT TEDIT
N
N
BORDERPSC-D
REV1BY
DRZ
-ATTEDIT
N
N
BORDERPSC-D
REV1DESCRIPTION
NO CHANGES THIS SHEET
-ATTEDIT
N
N
BORDERPSC-D
REV1DATE
1/2/07
-AT TEDIT
N
N
BORDERPSC-D
REV1ECN#
The problem is not that I don't have the "*" in the blank field. I've tried putting it in, and I get the same problem. "?" does not fix the problem either. At first I thought that AutoCAD didn't like the "--" that I put in the string field, but the error occurs before it even prompts for that string. I tried putting in letters instead just in case and that didn't work either.
-ATTEDIT
N
N
BORDERPSC-D
REV1
1
-AT TEDIT
N
N
BORDERPSC-D
REV1BY
DRZ
-ATTEDIT
N
N
BORDERPSC-D
REV1DESCRIPTION
-ATTEDIT
N
N
BORDERPSC-D
REV1DATE
1/2/07
-AT TEDIT
N
N
BORDERPSC-D
REV1ECN#
Re: TEXT REPLACEMEN T SCRIPT (RE)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-03-2007 01:53 PM in reply to:
hayj
Are you sure you have the attribute named REV1ECN#
in that block or could it be misspelled?
I tried a test and it seems to work but if the attribute doesn't exist in the block it will go to the command prompt.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-04-2007 07:18 AM in reply to:
hayj
Are you using the # in the attribute name as a wildcard or is it in the attribute name?
Sven Kloeck
Electrical Network Design
Sven Kloeck
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-04-2007 09:24 AM in reply to:
hayj
No, the attribute name is REV1ECN#. No wildcards. Just in case it was my mind playing tricks on me, I copied it straight out of AutoCAD and put it in the script. Could it be that AutoCAD doesn't like the #? Is there a wildcard symbol that I could put in its place so that it would recognize the first part of the attribute name? For instance, would it recognize REV1ECN*? I guess I could change the block to remove it, but that block has been used on thousands of drawings so far.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-04-2007 09:27 AM in reply to:
hayj
I guess I should have tried before asked. The "*" worked as a wildcard. AutoCAD must not have understood the #. Thanks for the help guys.
